Deliveries are indicated by the following indicated:
Tt_message => procid recipient_procid
Table 4-4 dexplains the messages you may receive during a dispatch trace.
Table 4-4 Reasons for Dispatch Trace
Message |
Explanation |
tt_message_send |
The message to send. |
tt_message_reject |
The message was rejected. |
tt_message_fail |
The message failed. |
tt_message_reply |
The reply to a message. |
tt_session_join |
The session to join. |
tt_file_join |
The file to join. |
tt_message_reply |
A client called the indicated function. |
tt_message_send_on_exit |
ttsession is dispatching on_exit messages for a client that disconnected before calling tt_close. |
tt_message_accept |
ttsession is dispatching messages that had been blocked while a ptype was being started. The started client has now called either tt_message_accept or tt_message_reply to indicate that the ptype should be unblocked. |
TT_ERR_PTYPE_START |
A ptype instance was started to receive the message, but the start command exited before it connected to ttsession. |
TT_ERR_PROCID |
ttsession lost its connection to the client that was working on this request. |
ttsession -> ttsession |
Another session wants this session to find recipients for the message. |
ttsession <- ttsession |
Another session wants to update (for example, fail) a message originating in this session. |
