There are three parts to this example which demonstrates how to retrieve a message from a catalog. The first part shows the message source file and the second part shows the method used to generate the catalog file. The third part shows an example program using this catalog.
The message catalog can be specified as follows:
example.msg file: $quote " $ every message catalog should have a beginning set number. $set 1 This is the set 1 of messages 1 "Hello world\n" 2 "Good Morning\n" 3 "example: 1000.220 Read permission is denied for the file %s.\n" $set 2 1 "Howdy\n"
This file is input to the gencat utility to generate the message catalog example.cat as follows:
gencat example example.msg
#include <locale.h> #include <nl_types.h> char *MF_EXAMPLE = "example.cat" main() { nl_catd catd; int error; (void)setlocale(LC_ALL, ""); catd = catopen(MF_EXAMPLE, 0); /* Get the message number 1 from the first set.*/ printf( catgets(catd,1,1,"Hello world\n") ); /* Get the message number 1 from the second set.*/ printf( catgets(catd, 2, 1,"Howdy\n") ); /* Display an error message.*/ printf( catgets(catd, 1, 4,"example: 100.220 Permission is denied to read the file %s.\n") , MF_EXAMPLE); catclose(catd); }
