Text Widget
Table 2-5  lists the Text[Field] resources that are locale-sensitive  or about which the developer of an internationalized application should  know.
Table 2-5  Locale-Sensitive Text[Field] Resources
 Widget Class
 Resource Name
XmSelectionBox
*textColumns: [The *columns resource specifies the initial width of the Text[Field] widget in terms of the number of characters to be displayed. In the case of a  variable width font or in a locale where the size of a character varies  significantly, a column is the amount of space required to display the widest  character in that locale's character repertoire. For example, a column  width of 10 guarantees that at least 10 characters of the current locale can  be displayed; it is possible (likely) that more than that number of characters  can be displayed in the allocated space.]
XmSelectionBox
*textString:
XmText
*columns:1
XmText
*modifyVerifyCallback:
XmText
*modifyVerifyCallbackWcs:
XmText
*value:
XmText
*valueWcs:
XmTextField
*columns:1
XmTextField
XmTextField
XmTextField
*value:
XmTextField
*valueWcs:
