UIL has three functions that are used to create font lists: FONT, FONTSET, and FONT_TABLE. The FONT and FONTSET functions create font list entries. The FONT_TABLE function creates a font list from these font list entries.
The FONT function creates a font list entry containing a font specification. The argument is a string representing an XLFD font name. The FONTSET function creates a font list entry containing a font set specification. The argument is a comma-separated list of XLFD font names representing a base name font list.
Both FONT and FONTSET have optional CHARACTER_SET declaration parameters that specify the font list element tag for the font list entry. In both cases, if no CHARACTER_SET declaration parameter is specified, UIL determines the font list element tag as follows:
If the module contains no CHARACTER_SET declaration and if the uil command was called with the -s option or the Uil() function was started with use_setlocale_flag set, the font list element tag is XmFONTLIST_DEFAULT_TAG.
Otherwise, the font list element tag is the code set component of the LANG environment variable, if it is set in the UIL compilation environment; or it is the value of XmFALLBACK_CHARSET if the LANGenvironment variable is not set or has no code set.
The FONT_TABLE function creates a font list from a comma-separated list of font list entries created by FONT or FONTSET. The resulting font list can be used as the value of a font list resource. If a single font list entry is supplied as the value for such a resource, UIL converts the entry to a font list.
