Figure 4-4 shows a UIL sample program on English and Japanese environments.
In the following sample program, LLL indicates locale text, which can be Japanese, Korean, Traditional Chinese, Greek, French, or others.
uil_sample.uil
!		sample uil file - uil_sample.uil
!			C source file - uil_sample.c
!				Resource file - uil-sample.resource
module Test
  		version = 'v1.0'
  		names = case_sensitive
  		objects = {
  			XmPushButton = gadget;
!		declare callback procedure
procedure
  		exit_CB		;
!		declare BulletinBoard as parent of PushButton and Text
object
  		bb : XmBulletinBoard {
  			arguments{
  				XmNwidth = 500;
  				XmNheight = 200;
  			controls{
  				XmPushButton
				pb1;
  				XmText
			text1;
!		declare PushButton
object
  		pb1 : XmPushButton {
  			arguments{
  				XmNlabelString = #Normal "LLLexit buttonLLL";
  				XmNx = 50;
  				XmNy = 50;
 			callbacks{
  				XmNactivateCallback = procedure exit_CB;
!		declare Text
  		text1 : XmText {
  			arguments{
  				XmNx = 50;
  				XmNy = 150;
end module;
 *			C source file - uil_sample.c
#include <Mrm/MrmAppl.h>
#include <locale.h>
void exit_CB();
static			MrmHierarchy				hierarchy;
static			MrmType			*class;
/*		specify the UID hierarchy list		  */
static			char			*aray_file[]=
  					{"uil_sample.uid"
 static			int		num_file = (sizeof aray_file / sizeof
 aray_file[0]);
/*		define the mapping between UIL procedure names	*/
/*		and their addresses			         					*/
static			MRMRegisterArg				reglist[]={
  					{"exit_CB",(caddr_t) exit_CB}
