There are several commands you can use to create widgets:
Creates an unmanaged widget.
There is a specific format for each of these commands that you must follow. For example, suppose you want to create an unmanaged push button widget as a child of the top-level widget. You can use either XtCreateWidget or XmCreatePushButton. The formats for these commands are:
XtCreateWidget variable name widgetclass $parent [resource:value ...]
XmCreatePushButton variable $parent name [resource:value ...]
The actual commands to create a push button widget are:
XtCreateWidget BUTTON button XmPushButton $TOPLEVEL XmCreatePushButton BUTTON $TOPLEVEL button
Each of the preceeding commands do exactly the same thing: create an unmanaged push button. Note that no resource values are set. Suppose that you want the background color of the push button to be red, and the foreground color to be black. You can set the values of these resources this way:
XtCreateWidget BUTTON button XmPushButton $TOPLEVEL \ background:Red \ foreground:Black XmCreatePushButton BUTTON $TOPLEVEL button\ background:Red \ foreground:Black
All of the C functions that create a widget return a widget ID, or ID. The corresponding dtksh commands set an environment variable equal to the widget ID. These are category 3 commands, so the first argument is the name of the environment variable in which to return the widget ID. The widget ID is an ASCII string used by dtksh to access the actual widget pointer. Either of the following commands could be used to create a new form widget; however, in each case the widget ID for the new form widget is returned in the environment variable FORM:
After either of these commands, you can use $FORM to reference the new form widget. For example, you could use this command to create a label widget within the new form widget:
XmCreateLabel LABEL $FORM name\ labelString:"Hi Mom" \ CH_FORM \ leftAttachment:ATTACH_FORM
There is a special widget ID called NULL, provided for cases where a shell script may need to specify a NULL widget. For example, to disable the defaultButton resource for a form widget, use the command XtSetValues $FORM defaultButton:NULL
