The XSolarisOvlCopyPaintType routine uses the paint type information of a specified rectangle in a source rectangle to control a fill operation in a specified rectangle in a destination rectangle. The source rectangle and destination rectangle can be any type of drawable. If the source rectangle is a transparent overlay, the paint type attribute of its pixels is used as the source of the copy, and the color information is ignored. If the source rectangle is any other type of drawable, the bit plane specified in the routine is treated as if it were paint type data and it is used for the copy. In this case, the bit plane must have only one bit set.
The syntax and arguments are shown below.
void XSolarisOvlCopyPaintType(Display *display, Drawable src, Drawable dst, GC gc, int src_x, int src_y, unsigned int width, unsigned int height, int dest_x, int dest_y, unsigned long action, unsigned long plane)
 display  |
 Specifies the connection to the X server.  |
 src  |
 Specifies the source drawable from which to obtain the paint type information.  |
 dst  |
 Specifies the destination drawable.  |
 gc  |
 Specifies the GC.  |
 src_x, src_y  |
 Specify the x and y coordinates of the upper-left corner of the source rectangle relative to the origin of the source drawable.  |
 width, height  |
 Specify the width and height of both the source and destination rectangles.  |
 dest_x, dest_y  |
 Specify the x and y coordinates of the upper-left corner of the destination rectangle relative to the origin of the destination drawable.  |
 action  |
 Specifies which paint type data is to be copied. This can be one of XSolarisOvlCopyOpaque, XSolarisOvlCopyTransparent, or XSolarisOvlCopyAll.  |
 plane  |
 Specifies the bit-plane of the src drawable to be used as paint type information when the source is not a transparent overlay.  |
src and dst must have the same screen, or a BadMatch error results.
Table 6-4 summarizes the possible combinations of src and dst and their actions. The left side of the table shows the possible src combinations. The top of the table shows the possible dst combinations. The actions A1-A4 are explained following the table.
Table 6-4 XSolarisOvlCopyPaintType Source/Destination Combinations and Actions|
 Source/Destination  |
 Overlay  |
 Drawable  |
 overlay  |
 A1  |
 A2  |
 drawable  |
 A3  |
 A4  |
A1--Opaque pixels in the source overlay cause the corresponding pixels in the destination to be filled with opaque color as specified by the fill attributes of the GC. Transparent pixels in the source cause the corresponding pixels in the destination to be filled with transparent paint.
A2--Opaque pixels in the source overlay cause the corresponding pixels in the destination to be filled according to the fill attributes of the GC. Transparent pixels in the source overlay cause the corresponding pixels in the destination to be filled according to the same fill attributes of the GC, but with the foreground and background pixels swapped.
A3--The pixels in the destination overlay are filled with opaque paint or made transparent as in A1 above depending on the bit values of the source drawable's plane. Bit values of 1 in the source are treated as if they were opaque pixels and bit values of 0 are treated as if they were transparent.
A4--The pixels in the destination drawable are filled with paint as in A2 above depending on the bit values of the source drawable's plane. Bit values of 1 in the source bit plane are treated as if they were opaque pixels and bit values of 0 are treated as if they were transparent.
The action argument specifies whether opaque paint (XSolarisOvlCopyOpaque), transparent paint (XSolarisOvlCopyTransparent), or both (XSolarisOvlCopyAll) should be operated upon. This allows a client to accumulate opaque or transparent paint.
If portions of the source rectangle are obscured or are outside the boundaries of the source drawable, the server generates Expose events, using the same semantics as XCopyArea.
This routine uses these GC components: function, plane-mask, fill-style, subwindow-mode, graphics-exposures, clip-x-origin, clip-y-origin, and clip-mask. It might use these GC mode-dependent components: foreground, background, tile, stipple, tile-stipple-x-origin, tile-stipple-y-origin.
XSolarisOvlCopyPaintType can generate BadDrawable, BadGC, BadMatch, and BadValue errors.
