Solaris X Window System Developer's Guide
Argument Types
XSolarisOvlSelectType is an enumeration defining two types of selections that can be done in XSolarisOvlSelectPartner. It is defined as:
typedef
enum { 	XSolarisOvlSelectBestOverlay, 	XSolarisOvlSelectBestUnderlay, }
XSolarisOvlSelectType;
XSolarisOvlVisualCriteria is a structure defining various criteria to be used during visual selection, along with indications of the stringency of the criteria. This structure is defined as:
typedef
struct { 	unsigned long					hardCriteriaMask; 	unsigned
long					softCriteriaMask 	int					c_class; 	unsigned int					depth; 	unsigned
int					minColors; 	unsigned int					minRed; 	unsigned int					minGreen;
	unsigned int					minBlue; 	unsigned int					minBitsPerRGB; 	unsigned
int					minBuffers; }
XSolarisOvlVisualCriteria;
hardCriteriaMask and softCriteriaMask are bitmasks whose values can be the logical OR of any of the following bitmasks:
#define
XSolarisOvlVisualClass										(1L<<0) #define
XSolarisOvlDepth										(1L<<1) #define
XSolarisOvl			MinColors							(1L<<2) #define
XSolarisOvlMinRed										(1L<<3) #define
XSolarisOvl		MinGreen								(1L<<4) #define
XSolarisOvl			MinBlue							(1L<<5) #define
XSolarisOvlMinBitsPerRGB										(1L<<6) #define
XSolarisOvl			MinBuffers							(1L<<7) #define
XSolarisOvlUnsharedPixels										(1L<<8) #define
XSolarisOvlUnsharedColors										(1L<<9) #define
XSolarisOvlPreferredPartner										(1L<<10)
