KCMS Test Suite User's Guide
Evaluate
Script Name
IC_eval.scr
Concept
IC_eval.scr performs several EVAL: commands on different image types (computer-generated graphics, scanned images). The resolution of the images varies from 72 dpi to 200 dpi. It saves the TIFF file outputs of the evaluate tests to allow for subjective evaluation of color quality.
Note -
Subjective evaluation of the images requires the following devices: Apple 13" monitor, Kodak XL 7720 printer, Kodak ColorEdge 1550 copier-printer. Images used in this test are scanned on a Microtek 600ZS scanner.
Description
This script demonstrates that the KCMS framework can successfully perform the EVAL: command under varying input and output conditions. First several profiles are loaded, and the CONNECT: command is used to create forward, reverse, and simulate test profiles. Test images are evaluated through each of the profiles that were previously connected. After these operations are completed, all the profiles are freed from memory with the FREE: command.
Verification
Each command in this script is expected to return successfully. As a post-test exercise, you should generate and examine each of the images output from the EVAL: command as an additional verification that the evaluate tests completed successfully.
