Table 3-2 presents the CONNECT: command keywords and their descriptions.
Table 3-2 CONNECT: Command Keywords|
Keyword |
Description |
Name= |
Is the reference name that will be assigned to the new profile if the CONNECT:command completes successfully. |
Reference= |
Is the name that was assigned when the profiles were loaded or created. |
Count= |
Is the number of profiles that will be used in the connection. Currently two profiles are used to connect forward and reverse profiles. Three profiles are used to connect simulate profiles. |
Operation= |
Defines the operation load hint that will be used to connect the new profile. This keyword has the operation and content hint values shown in Table 3-3 . It indicates what transforms in the profiles will be loaded and connected in the final (complete) profile. An Operation= keyword can appear more than once in a single script command. Multiple operations are logically OR'd together. |
XStatus= |
The default expected status is KcsSuccess. If the script command is expected to complete successfully, the XStatus= keyword is not required. In cases where a script command is expected to return a non- success status, the XStatus= is followed by the corresponding expected, non-success status in hexadecimal format. |
Table 3-3 shows the acceptable values for the Operation= keyword.
Table 3-3 CONNECT: Command Operation= Keyword Values|
Value |
Load Hint Set |
Forward; |
KcsOpForward |
Reverse; |
KcsOpReverse |
Simulate; |
KcsOpSimulate |
Gamut; |
KcsOpGamutTest |
OpsAll; |
KcsOpAll |
ContUnkn; |
KcsContUnknown |
Graphics; |
KcsContGraphics |
Image; |
KcsContImage |
ColorMtrc; |
KcsContColorimetric |
ContAll; |
