Table 3-7 presents the FREE: command keywords and their descriptions.
Table 3-7 FREE: Command Keywords
Keyword |
Description |
Reference= |
Is the name that was assigned to the profile either when it was loaded or created using the CONNECT: or CREATE: command. If the file was loaded with the LOAD: or CREATE: command, the file is closed. |
XStatus= |
The default expected status is KcsSuccess. If the script command is expected to complete successfully, the XStatus= keyword is not required. In cases where a script command is expected to return a non-success status, the keyword is followed by the corresponding expected, non-success status in hexadecimal format. |
