Table 3-9 presents the LOAD: command keywords and their descriptions.
Table 3-9 LOAD: Command Keywords|
Keyword |
Description |
Reference= |
Is the name that this profile will be referred to in subsequent script commands. In the context of the test script, it is the profile name. |
Profile= |
Is the file name of the profile. All profiles must be located in the kcmstest/profiles directory. This keyword may name a pre-made profile or a profile that is created as part of the test script. |
Handling= |
Describes how the profile will be handled. This keyword has the values listed in Table 3-10 . |
LoadHint= |
Defines the load hint that will be used to load the profile. This keyword has the values listed in Table 3-11 . In the table, the keyword value is followed by the corresponding value set in the loadHints parameter passed to the KcsLoadProfile()() function. A LoadHint= keyword can appear more than once in a single script command. Multiple load hints are logically OR'd together. |
Operation= |
Defines the operation load hint that will be used to load the profile. This keyword has the operation and content hint values listed in Table 3-12 . In the table, the keyword is followed by the corresponding value set in the loadHints parameter passed to the KcsLoadProfile()() function. An Operation= keyword can appear more than once in a single script command. Multiple operations are logically OR'd together. |
KcsDisplay= |
Is the X Window System display (display:screen) number in the form of 0.0, 0.1, and so forth. Use this keyword for multiheaded systems. |
KcsHost= |
Is the host name of the workstation from which a profile is to be read. You must have the kcms_server(1) daemon running to access another host through the network. |
XStatus= |
The default expected status is KcsSuccess. If the script command is expected to complete successfully, the XStatus= keyword is not required. In cases where a script command is expected to return a non-success status, the keyword is followed by the corresponding expected, non-success status in hexadecimal format. |
Table Table 3-10 presents the LOAD: command Handling= keyword values.
Table 3-10 LOAD: Command Handling= Keyword Values|
Value |
Description |
File |
Sets Desc.type = KcsFileProfile |
KcsSolarisFile |
Sets Desc.type = KcsSolarisProfile |
KcsWindow |
Sets Desc.type = KcsWindowProfile |
Memory |
Sets Desc.type = KcsMemoryProfile |
Table 3-11 presents the LOAD: command LoadHint= keyword values.
Table 3-11 LOAD: Command LoadHint= Keyword Values|
Value |
Load Hint Set |
AllNow |
KcsLoadAllNow |
AllWhen |
KcsLoadAllWhenNeeded |
LoadAttr |
KcsLoadAttributeNow |
MinMem |
KcsLoadMinimalMemory |
PurgeMem |
KcsPurgeMemoryNow |
LoadWhenNever |
KcsLoadNever |
LoadWhenNow |
KcsLoadNow |
LoadWhenNeeded |
KcsLoadWhenNeeded |
LoadWhenIdle |
KcsLoadWhenIdle |
UnloadWhenNow |
KcsUnloadNow |
UnloadWhenFree |
KcsUnloadWhenFreed |
UnloadWhenNeeded |
KcsUnloadWhenNeeded |
UnloadAfter |
KcsUnloadAfterUse |
WhatAttr |
KcsAttributes |
WhatAll |
KcsAll |
WhatEffects |
KcsEffect |
Table 3-12 presents the LOAD: command Operation= keyword values.
Table 3-12 LOAD: Command Operation= Keyword Values|
Value |
Load Hint Set |
OpsAll |
KcsOpAll |
ContUnkn |
KcsContUnknown |
Graphics |
KcsContGraphics |
Image |
KcsContImage |
ColorMtrc |
KcsContColorimetric |
ContAll |
