Table 3-16 presents the OPTIMIZE: command keywords and their descriptions.
Table 3-16 OPTIMIZE: Command Keyword Values|
Keyword |
Description |
Reference= |
Is the name that was assigned when the profiles were loaded, created, or connected. |
Optimization= |
Sets the optimization type. This keyword has the values shown in Table 3-17 . In the table, the keyword value is followed by the corresponding value set in the optimizationType parameter passed to the KcsOptimizeProfile()() function. Multiple optimizations are logically OR'd together. |
Callbacks= |
Causes kcmstest to call the KcsSetCallback()() function. Callbacks are registered in the log file. |
XStatus= |
The default expected status is KcsSuccess. If the script command is expected to complete successfully, the XStatus= keyword is not required. In cases where a script command is expected to return a non- success status, the XStatus= is followed by the corresponding expected, non-success status in hexadecimal format. |
Table 3-17 presents the OPTIMIZE: command Optimization= keyword values.
Table 3-17 OPTIMIZE: Command Optimization= Keyword Values|
Value |
Optimization Type Set |
None |
KcsOptNone |
Accuracy |
KcsOptAccuracy |
Speed |
KcsOptSpeed |
Size |
