If at any time during script execution, a KCMS framework API function call returns with an unexpected status code, the test is immediately aborted. For a list of all the status codes strings and their values, see Appendix A, Status Codes .
It may be your intention to have a status code returned that indicates an error because you deliberately set up a script to test an error condition. The script commands provide the optional keyword XStatus, which allows you to do this. For details, see the script command descriptions in Chapter 3, KCMS Test Suite Commands . Also see "Checking Status Codes" .
