The auto-kcmstest script allows you to run the complete test suite in icc.ini, including scripts in the icc.ini file list that access a remote host. This script is located in the kcmstest directory.
You may need to edit the script to change path information.
To run this script, do not set the environment variable KCMSROOT
with the setenv command. Instead, provide two arguments: the KCMSROOT
environment variable as the first argument and the remote host name as the second, for example
%auto-kcmstest /opt/SUNWddk/kcms dusk
In this example, /opt/SUNWddk/kcms is the KCMSROOT
environment variable and dusk is the remote host name. Note that if you are in the directory where auto-kcmstest() is located, only the host argument is needed, for example
%auto-kcmstest dusk
