After you have run the complete test suite using auto-kcmstest and auto-kcmstest-root, you can get an automated failure and performance report by running the kcms-testreport command. This command takes two arguments: the name of the test log and the report title. Very likely, you would redirect output to a file of the same name as the report title, for example
%kcms-testreport log/testall.log my_test_1 > my_test_2
In this example, my_test_1 is the report title and my_test_2 is the output filename.
