KCMS Test Suite User's Guide
Connect Profiles
Script Name
IC_connect.scr
Concept
IC_connect.scr connects various types of device profiles into complete profiles. It evaluates using the complete profiles.
Description
This script demonstrates that the KCMS framework can connect a variety of profiles in a variety of ways. It loads profiles of the following types: scanner, monitor, and printer. After the profiles are loaded, the script makes a variety of connections with the CONNECT: command.
Initially the script works with scanner and monitor profiles, creating complete profiles, one for each of the following transformation types: forward, reverse, and gamut. It evaluates using the profiles containing the forward transformations.
Next it loads monitor and printer profiles and creates complete profiles including forward, reverse, and simulate transformations. It creates additional profiles that not only contain these transformations but have image content hints specified as well. Then it evaluates using the forward and simulate profiles. To save disk space, outputs are not saved.
Finally the script works with scanner and printer profiles.
At various points, the script evaluates the connected profiles to verify that the new profile can be used to process image data. Additionally, it varies the content of the connected profile (image, content unknown, and so forth).
Verification
Each command is expected to return successfully.
