KCMS Test Suite User's Guide
Connect Error
Script Name
IC_conerr.scr
Concept
IC_conerr.scr attempts to connect various types of device profiles into complete profiles, testing the error handling capabilities of the CONNECT: command.
Description
This script demonstrates that the KCMS framework can perform the CONNECT: command under a variety of error conditions and return the correct status. The script performs the CONNECT: command with the following error conditions:
Verification
Commands that are expected to fail will have the expected failure status provided as part of the CONNECT: script command.
