IC_gray.scr creates a gray profile and sets attributes.
This script demonstrates that the KCMS framework can create a gray device color profile and set several attributes. It performs the following sequence of events first on a display profile and then on an input profile.
It uses the CREATE: command to create the new profile and sets several attributes with the SETATTR: command. Then it uses the GETATTR: command to get the attributes to verify that they are properly set. It saves the profile and frees it from memory. Then it reloads the profile and again verifies the attributes.
All the commands are expected to complete successfully.
