IC_sun_update.scr verifies a bug in the UPDATE: command.
This script demonstrates that the KCMS framework can update a monitor profile several times. It loads, updates, and saves a monitor profile to a different name three times and frees the updated profiles. Then the script reloads each of the saved monitor profiles and a scanner profile. It connects each monitor profile to the scanner profile, specifying the forward transformation operation and evaluates the results. Finally, the script frees all the profiles from memory.
All the commands are expected to complete successfully.
