KCMS Test Suite User's Guide
IC_xwindow.scr
Concept
IC_xwindow.scr:
Description
This script demonstrates that the KCMS framework can access profiles locally and across the network. First it loads the default X Window System profile from the local host. Then it loads a Solaris profile from another host machine. Finally it frees the profiles from memory.
Note -
The kcms_server(1) daemon must be running on the remote most. If it is not running, type kcms_server in a command shell as root on the remote host.
Verification
All the commands are expected to complete successfully, provided the kcms_server(1) daemon is running on the current machine.
