KCMS Calibrator Tool Loadable Interface Guide
Initialization
During initialization, Calibrator Tool takes a handle to the dynamically opened module and accesses the KCMSCMonInit symbolic name using dlsym(3X). If it finds the name, it initializes and allocates space for the visual data.
The tool calls KCMSCMonInit() to allow the loadable module to initialize the serial port for the hardware colorimeter (if it uses one to take measurements), to start its own GUI-based application, and to make any additional preparations necessary to measure monitor data.
Note -
The sample modules described in this guide set up the application user interface during initialization using included source code from TeleUSE (Motif GUI builder) and the X Toolkit library (available with Solaris 2.5 and later). (Refer to the colorsense() and XSolarisVisualGamma() source files.) Be aware that you are not required to use this code in the design of your module. The examples are an implementation only. All or parts of them can be used as a template, depending on your needs.
