The following is an example of how to remove a configuration entry from the OWconfig file. Sample user responses are enclosed in brackets ([]).
ATTENTION: You must be root to update the OWconfig file. Are you inserting an OWconfig entry? y/n [n] To remove an OWconfig entry: Enter the unique name for your driver for removal from the OWconfig file. [mydriver] This is the OWconfig entry to remove. OK? y/n class = KCMS_CALIBRATE name = mydriver [y] Do you have more entries to remove? y/n [n]
The OWconfig_calibrate program removes the last entry in the OWconfig file.
Try removing the entry you inserted following Example 3-4 . Use the procedure outlined below:
Run the OWconfig_calibrate program again. Be sure you are root.
Fill in the user responses shown in Example 3-4 .
Check the OWconfig file.
The entry should no longer appear at the end of the file.
