KcsStatus KcsCleanup()XXXX()(); |
If you supply the KcsCleanup()XXXX()()entry point, the KCMS framework calls it when the shareable object is unloaded for the last time (when KcsDLOpen()XXXXCount = 0()). This cleans up shareable objects when they are no longer needed.
