Any profile you want to include in the KCMS library must be named according to specified conventions to avoid name clashes and promote portability. The paragraphs below explain how to name and install your profile so that it can be automatically used in the KCMS framework.
The KCMS profile name is a filename with the following naming convention:
<CMM ID><stock symbol><device>.<type> |
Table 2-5 describes the fields in the profile filename:
Table 2-5 Profile Filename Description|
Profile Filename Field |
Description |
CMM ID |
A mnemonic. Solaris-supplied profiles use kcms as the CMM ID. Choose your own mnemonic for profiles you create. |
stock symbol |
Short mnemonic used by the stock market for your company or a unique identifier. |
device |
Unique string identifying the device or color space. See Table A-1 for devices supported by Solaris. |
type |
ICC profile format standard filename suffixes. See Table 2-6 . |
Table 2-6 describes the various filename suffixes for profiles for the Solaris environment.
Table 2-6 Profile Filename Suffixes|
Filename Suffix (type) |
Description |
inp |
Input devices (scanners, digital cameras and Photo CDs) |
mon |
Display devices (CRTs and LCDs) |
out |
Output devices such as printers |
spc |
Color space conversion transformations |
link |
Device link transformations |
abst |
If you use the file type KcsSolarisFile in the KcsLoadProfile()() function, you must install profiles where the KCMS framework can locate them . The KCMS framework searches for profiles in the following directories in the order listed below:
Local current directory
Typically a CMM creates profiles in the directory in which it is being run.
Directories specified by the KCMS_PROFILES environment variable
KCMS_PROFILES is a colon-separated list of directory paths to profiles. You can set this variable on a per-user or work-group basis. You may want to use this variable to set the path to temporary profiles your CMM creates.
/etc/openwin/devdata/profiles
This directory contains the local or machine-specific copies of configured profiles, for example, X Window System visual profiles.
/usr/openwin/etc/devdata/profiles
This directory always contains read-only files.
All profiles for distribution (whether you create them or they are supplied with the Solaris operating system) should be written as superuser and read only to protect them from being overwritten.
If you use the file type KcsFile in the KcsLoadProfile()() function, when the application opens the profile, you can name it anything you want.
For a list of the devices supported by the KCMS framework, see Appendix A, Supported Devices .
