KCMS CMM Developer's Guide
Example
Example 5-1 shows you how to use the entry points when creating a KcsProfile instance.
Example 5-1 KcsProfile Class Entry Points Example
/* Required entry points
*/ extern long KcsDLOpenProfCount = 0;  /* Construct a profile object using
KcsIO */ KcsProfile * KcsCreateProf(KcsStatus *aStat, KcsIO *aIO) { 	//Create
the new derivative 	return (new KcsProfileKCMS(aStat, aIO)); } /* Construct an
in-memory profile object using the ids */ KcsProfile *
KcsCreateProfBlnk(KcsStatus *aStat, KcsId aCmmId,  	KcsVersion aCmmVersion,
KcsId aProfId,  	KcsVersion aProfVersion) { 	//Create the new derivative
	return(new KcsProfileKCMS (aStat, aCmmId, aCmmVersion,  		aProfId,
aProfVersion)); } /* Optional entry points */ KcsStatus KcsInitProf(long
libMajor, long libMinor, long *myMajor,  		long *myMinor) { 	// Set up the
return values 	*myMajor = KCS_MAJOR_VERSION; 	*myMinor = KCS_MINOR_VERSION;
	//Check the major version 	if (libMajor != KCS_MAJOR_VERSION) 		return
(KCS_CMM_MAJOR_VERSION_MISMATCH);  	//Currently, if minor version of library
is less than the KCMS  	// minor version, return an error. 	if (libMinor !=
KCS_MINOR_VERSION) 		return (KCS_CMM_MINOR_VERSION_MISMATCH);  	//Library
guarantees if your minor version number is greater than 	//KCMS minor version
number, it will handle it. No more init. 	return(KCS_SUCCESS); }  KcsStatus
KcsCleanupProf() { 	/* Clean up is performed in the destructor */ 	return;
