KCMS CMM Developer's Guide
Examples
The following example shows you how to use the entry points when creating a KcsProfileFormat derivative.
Example 6-1 KcsProfileFormat Class Entry Points Example
extern long
KcsDLOpenPfmtCount = 0;  /* Global initialization - constructor can be used */
KcsStatus KcsInitPfmt(long libMajor, long libMinor, long *myMajor, long
*myMinor) { 	// Set up the return values 	*myMajor = KCS_MAJOR_VERSION;
	*myMinor = KCS_MINOR_VERSION;  	//Check the major version 	if (libMajor !=
KCS_MAJOR_VERSION) 		return (KCS_CMM_MAJOR_VERSION_MISMATCH);  	//Currently,
if minor version of library is less than the KCMS  	// minor version, return
an error. 	if (libMinor != KCS_MINOR_VERSION) 		return
(KCS_CMM_MINOR_VERSION_MISMATCH);  	//Library guarantees if your minor version
number is greater than 	//KCMS minor version number, it will handle it. No
more init. 	return(KCS_SUCCESS); }  /* Clean up global initialization */
KcsStatus KcsCleanupPfmt() { 	KcsStatus sStat; 	return(KCS_SUCCESS); }  /*
Create a profile format derivative based on information passed in,  * there is
profile data associated with it. Corresponds to the  * KcsCreateProfile() API
call. */ KcsProfileFormat * KcsCreatePfmtBlnk(KcsStatus *aStat, KcsId aCmmId,
	KcsVersion aCmmVersion, KcsId aProfId, KcsVersion aProfileVersion) {
	//Create the new derivative 	return(new KcsProfileFormatInterColor3_0(aStat,
aCmmId,  		aCmmVersion, aProfId, aProfileVersion)); }  /* Create a profile
format derivative using the supplied IO.  * Corresponds to the
KcsLoadProfile() API call. */ KcsProfileFormat * KcsCreatePfmt(KcsStatus
*aStat, KcsIO *aIO) { 	//Create the new derivative 	return(new
KcsProfileFormatInterColor3_0(aStat, aIO));
