The base class supports the caching objects and transformation map saving. It contains the KcsXform * array, an KcsAttribute * and supports the getObject()() and setObject()() overloads. Most derivative profile formats implement these virtuals: initEmptyFormat()(), isSupported()(), load()(), and save()().
A derivative can define and use the base class data elements protected during load()(), and the base class passes them to you.
