Saving trickles down throughout the whole connected hierarchy. Any change to any transformation in the sequence is saved when the sequence is saved. This happens because the sequence shares the transformations passed to it. The instance also gets the chunk Ids from each transformation in the list. It then packs these and other state information into a memory block and does a setChunk()() to allow lookup of this transformation list upon a load request to the sequence.
When requested to save in universal format (see "Universal" for details), the sequence does a composition that generates one transformation that is saved in this format.
