The list of transformations is represented by a memory block of pointers to KcsXforms. The size of the block is incremented by a constant each time the current block fills with pointers. A few methods access and edit the list.
Note that a NULL parent starts the list based on this sequence. You must pass the last parent found into the next call to getNextXform()() and use the same object for invocations of this method. getNextXform()() returns KCS_END_OF_XFORMS when it reaches the end of the transformations in the sequence. All getNextXform()() calls are sequential. Any sharing of an object must take this into account. Otherwise, if the calls to getNextXform()() are not synchronized, two different results may occur. getNextXform()() works correctly when called on a sequence that is a part of another sequence: it runs through that subsequence only.
For example, given sequence A (a->B->e) and sequence B (c->d) where a, c, d, and e are primitive transformation types: A->GetNext()(). If GetNextXform()() is called (starting with a NULL parent **) until it returns KCS_END_OF_SEQUENCE, it returns transformations in the following order: a, c, d, e, B->GetNext()(). If called (starting with a NULL parent **) until it returns KCS_END_OF_SEQUENCE, it returns transformations in the following order: c, d. It also skips over all sequences of 0 transformations as if they are not even there.
