KCMS CMM Developer's Guide
Mandatory
When you derive from a KcsIO class, the mandatory external entry points are:
extern
long KcsDLOpenIOCount; KcsIO *KcsCreateIO(KcsStatus *aStat,  	const
KcsProfileDesc *aDesc);
The KcsCreateIO()() method creates an instance of a KcsIO derivative. The instance is determined by aDesc->type, which contains the derivative portion of the class identifier (see "Creating OWconfig File Entries" ).
