KCMS CMM Developer's Guide
KcsAttributeSet
Each KcsProfileFormat base class contains a pointer to a KcsAttributeSet object and handles all of the functionality for attributes.Using the KcsIO class associated with the parent KcsProfile, the KcsAttributeSet object can load itself from the static store. KcsAttributeSet does not use the KcsIO class directly; it uses the KcsChunkSet utility class to access the static store. KcsChunkSet knows how to handle the mapping from desired information blocks to its actual location in the static store. KcsChunkSet and KcsIO have no knowledge of the contents of the data. That is left to the calling class.
