Freeing a profile causes each of the objects pointed to by the profile Id in the framework's global array to release all of its associated data. If a given object is a shared or reference-counted object, the memory is released only if the reference count drops to zero.
Freeing a profile loaded via KcsSolarisProfile or KcsXWindowProfile closes the associated file descriptor or remote procedure call (RPC) connection if the file is located on a remote machine. Use the KcsFreeProfile(profile)() KCMS "C" API call to free a profile.
