Java on Solaris 7 Developer's Guide
Vectors
Vector is convenient to use, but inefficient. For best performance, use it only when the structure size is unknown, and efficiency is not a concern. When using Vector, ensure that elementAt() is not used inside a loop, as performance will degrade. Use Vector only when you have an array with the following characteristics:
