Unlike orange, most expressions cannot be specified so easily. The expression itself might be too long, or, more commonly, the class of desired expressions is too large; it might, in fact, be infinite.
Using lex operators -- summarized in Table 2-1 -- you can form regular expressions for any expression of a certain class. The + operator, for instance, means one or more occurrences of the preceding expression, the ? means 0 or 1 occurrences of the preceding expression (which is equivalent to saying that the preceding expression is optional), and the * means 0 or more occurrences of the preceding expression. So m+ is a regular expression that matches any string of ms:
mmm m mmmmm
and 7* is a regular expression that matches any string of zero or more 7s:
77 77777 777
The empty third line matches because it has no 7s in it at all.
The | operator indicates alternation, so that ab|cd matches either ab or cd. The operators {} specify repetition, so that a{1,5} looks for 1 to 5 occurrences of a, and A(B{1,4}) matches ABC, ABBC, ABBBC, and ABBBBC (notice the use of parentheses, (), as grouping symbols).
Brackets, [], indicate any one character from the string of characters specified between the brackets. Thus, [dgka] matches a single d, g, k, or a. The characters between brackets must be adjacent, without spaces or punctuation.
The ^ operator, when it appears as the first character after the left bracket, indicates all characters in the standard set except those specified between the brackets. (Note that |, {,}} and ^ may serve other purposes as well.)
Ranges within a standard alphabetic or numeric order (A through Z, a through z, 0 through 9) are specified with a hyphen. [a-z], for instance, indicates any lowercase letter.
[A-Za-z0-9*&#]
This is a regular expression that matches any letter (whether upper or lowercase), any digit, an asterisk, an ampersand, or a #.
Given the following input text, the lexical analyzer with the previous specification in one of its rules will recognize *, &, r, and #, perform on each recognition whatever action the rule specifies (we have not indicated an action here), and print the rest of the text as it stands:
$$$$?? ????!!!*$$ $$$$$$&+====r~~# ((
To include the hyphen character in the class, have it appear as the first or last character in the brackets: [-A-Z] or [A-Z-].
The operators become especially powerful in combination. For example, the regular expression to recognize an identifier in many programming languages is:
[a-zA-Z][0-9a-zA-Z]*
An identifier in these languages is defined to be a letter followed by zero or more letters or digits, and that is just what the regular expression says. The first pair of brackets matches any letter. The second, if it were not followed by a *, would match any digit or letter.
The two pairs of brackets with their enclosed characters would then match any letter followed by a digit or a letter. But with the *, the example matches any letter followed by any number of letters or digits. In particular, it would recognize the following as identifiers:
e not idenTIFIER pH EngineNo99 R2D2
Note that it would not recognize the following as identifiers because not_idenTIFIER has an embedded underscore; 5times starts with a digit, not a letter; and $hello starts with a special character:
not_idenTIFIER 5times $hello
A potential problem with operator characters is how to specify them as characters to look for in a search pattern. The previous example, for instance, does not recognize text with a * in it. lex solves the problem in one of two ways: an operator character preceded by a backslash, or characters (except backslash) enclosed in double quotation marks, are taken literally, that is, as part of the text to be searched for.
To use the backslash method to recognize, say, an * followed by any number of digits, you can use the pattern:
\*[1-9]*
To recognize a \ itself, we need two backslashes: \\. Similarly, "x\*x" matches x*x, and "y\"z" matches y"z. Other lex operators are noted as they arise; see Table 1-1:
Table 2-1 lex Operators|
Expression |
Description |
| \x |
x, if x is a lex operator |
| "xy" |
xy, even if x or y is a lex operator (except \) |
| [xy] |
x or y |
| [x-z] |
x, y, or z |
| [^x] |
Any character but x |
Any character but newline |
| ^x |
x at the beginning of a line |
| <y>x |
x when lex is in start condition y |
| x$ |
x at the end of a line |
| x? |
Optional x |
| x* |
0, 1, 2, ... instances of x |
| x+ |
1, 2, 3, ... instances of x |
| x{m,n} |
m through n occurrences of x |
| xx|yy |
Either xx or yy |
| x | |
The action on x is the action for the next rule |
| (x) |
x |
| x/y |
x but only if followed by y |
| {xx} |
The translation of xx from the definitions section |
