m4 provides three built-in macros for doing integer arithmetic. incr() increments its numeric argument by 1. decr() decrements by 1. So, to handle the common programming situation in which a variable is to be defined as "one more than N," you would use:
define(N, 100) define(N1, `incr(N)')
That is, N1 is defined as one more than the current value of N.
The more general mechanism for arithmetic is a built-in macro called eval(), which is capable of arbitrary arithmetic on integers. Its operators, in decreasing order of precedence, are
+ - (unary) (**(** (** / % + - == != < <= > >= ! ~ & | ^ && ||
Parentheses may be used to group operations where needed. All the operands of an expression given to eval() must ultimately be numeric. The numeric value of a true relation (like 1 > 0) is 1, and false is 0. The precision in eval() is 32 bits.
As a simple example, you can define M to be 2(**(**N+1 with
define(M, `eval(2(**(**N+1)')
Then the sequence
define(N, 3) M(2)
