To remove all traces of the most recent delta, you can use the rmdel subcommand. You must specify the SID using -r. In most cases, using fix is preferable to rmdel, since fix preserves a record of "deleted" delta, while rmdel does not (refer to sccs rmdel(1) for more information).
