SCCS recognizes and expands certain keywords in a source file, which you can use to include version-dependent information (such as the SID) into the text of the checked-in version. When the file is checked out for editing, ID keywords take the following form:
%C%
where C is a capital letter. When you check in the file, SCCS replaces the keywords with the information they stand for. For example, %I% expands to the SID of the current version.
You would typically include ID keywords either in a comment or in a string definition. If you do not include at least one ID keyword in your source file, SCCS issues the diagnostic:
No Id Keywords (cm7)
For more information about ID keywords, refer to "Incorporating Version-Dependent Information by Using ID Keywords ".
