The thread_create probe traces kernel thread creation. It records the process identifier, the kernel thread identifier, and the kernel address of the start routine of the new thread.
The thread_exit probe records the termination of the current thread.
Probes that trace thread-state transitions are called microstate probes. They record a thread state and, optionally, a thread identifier. If a thread identifier is provided, the state change applies to the indicated thread. Otherwise, it applies to the writing thread.
Thread state values use the microstate constants defined in <sys/msacct.h>. The states are recorded as shown in Table 1-7.
Table 1-7 Thread Microstate Constants|
State |
Explanation |
user |
Running in user mode |
system |
Running in system mode |
tfault |
Initial state for user text fault |
dfault |
Initial state for user data fault |
trap |
Initial state for other trap |
user_lock |
Asleep, waiting for user-mode lock |
sleep |
Asleep for any other reason |
wait_cpu |
Waiting for a CPU (runnable) |
stopped |
Stopped (/proc, jobcontrol, lwp_stop) |
The kernel does not trace transitions between the system and user states that are implied by system calls. This is to reduce trace volume. You need to enable the system call probes to get this information; for convenience, they are automatically enabled for you when you enable probes with the thread key.
System call entry and exit probes identify the system operations explicitly requested by user code.
The syscall_start probe marks the start of a system call, and records the system call number. The probe does not capture system call arguments, because this is fairly expensive. (Some of this information can be captured by interposing on the C library entry points at the user level.) The syscall_start probe also implicitly marks the current thread as entering the system state.
The syscall_end probe marks the end of a system call, and records the two return values of the call, as well as the errno value. The syscall_end probe also implicitly marks the current thread as entering the user state.
System call implementation at this level can change from release to release. Do not rely on a consistent mapping of system calls to numbers.
The virtual memory subsystem (VM) probes provide information on page faults, page I/O, the page daemon, and the swapper.
Page fault probes relate virtual addresses with fault types and with files (vnodes).
The address_fault probe traces address-space faults; it records the faulting virtual address, the type of fault, and the desired access protection.
The fault type and access type values use the constants defined in <vm/seg_enum.h>. Fault types are invalid page (minor fault), protection fault, or software requests to lock and unlock pages for physical I/O (softlock and softunlock). Access types are read, write, execute and create.
The major_fault probe traces major page faults; it records the vnode and offset (which together identify a file system page) from which the fault should be resolved. This data can be correlated with the immediately preceding address_fault event for the current thread to obtain the faulting virtual address.
The anon_private probe traces copy-on-write faults.
The anon_zero probe traces zero-fill faults.
The page_unmap probe marks the dissociation between a physical page and a file system page (for example, when a page is renamed or destroyed).
The pagein probe traces the initiation of a pagein request; it records the vnode, offset, and size of the pagein.
The pageout probe traces the completion of a pageout request; it records the number of pages paged out, the number of pages freed, and the number of pages reclaimed after the pageout.
Iterations of the page daemon (page stealer) are traced by two probes: pageout_scan_start and pageout_scan_end. The probes report the number of free pages needed before the scan, the number of pages examined during the scan, and the free page counts before and after the scan. Potentially, more pages are freed when pageout requests queued by the scan are completed.
Three probes trace the activity of the swapper.
The swapout_process probe traces the swapping out of a process address space; it records the process identifier and the total number of pages either freed or queued for output.
The swapout_lwp probe traces the swapping out of an LWP's stack pages; it records the LWP's identity and the number of pages queued for output.
The swapin_lwp probe traces the swapping in of an LWP's stack pages; it records the LWP's identity and the number of stack pages brought in.
The strategy probe traces the initiation of local block device I/O by the kernel. It records the device number, logical block number, size, buffer pointer, and buffer flags associated with the transfer. The flag values are the buffer status flags as defined in <sys/buf.h>.
The biodone probe traces the completion of a buffered I/O transfer, that is, calls to the kernel biodone(9f) routine. It records the device number, logical block number, and buffer pointer associated with the transfer.
Physical (raw) I/O is traced by two probes in physio(9f): physio_start and physio_end. These probes record the device number, offset, size, and direction of the I/O transfer.
The thread_queue probe traces thread scheduling; it records the thread identifier of the scheduled thread, the CPU associated with the dispatch queue on which it is placed, the thread's dispatch priority, and the current number of runnable threads on the dispatch queue.
