The parsing actions of error and accept can be simulated in an action by use of macros YYACCEPT and YYERROR. The YYACCEPT macro causes yyparse() to return the value 0; YYERROR causes the parser to behave as if the current input symbol had been a syntax error; yyerror() is called, and error recovery takes place.
These mechanisms can be used to simulate parsers with multiple end-markers or context-sensitive syntax checking.
