While print search methods work in AnswerBook, too, it's much faster to search for messages through the search utility in the AnswerBook Navigator.
Bring up AnswerBook
$ answerbook
Click Select on the Search button
Enter the words or pattern to search for in the "Search Library For:" pane
Double-click Select on an entry in the resulting list. Although any of the entries might contain the information you're looking for, those from this book are most likely to be what you want.
If your first search doesn't find the message, consider altering the search pattern. Remember that this book contains only a small percentage of possible messages.
In general, you are most likely to find a documented message in the AnswerBook search pane when you enclose the searched-for words in quotation marks ("") or in parentheses ().
You can search in the AnswerBook Navigator for text containing specific single words, phrases that contain spaces, words near one another, and word variations.
See"Using the AnswerBook Software" in OpenWindows User's Guide for more detailed information about the AnswerBook search.
Table 1-1 AnswerBook Search Pattern Matching|
To search for |
Such as |
Use |
Single words |
installing, le0, group |
The words |
Phrases with spaces |
Installing Packages |
Quotation marks ("") around the phrase |
Words near one another |
Installing...Server |
Parentheses ( ( ) ) |
Word variations |
delete, deleting, deletion |
Asterisks (*) and hyphens (-) |
The following example shows some of the possible matches for specific AnswerBook Navigator searches.
Table 1-2 AnswerBook Search Results|
Searching With |
Finds These (for Example) |
Installing |
Installing XIL Device Handlers (XIL Device Porting and Extensibility Guide) Installing Packages on a Server for... (Application Packaging Developer's Guide) |
"Installing Packages" |
Installing Packages on a Server for... (Application Packaging Developer's Guide) Installing Packages for Clients on a Server (Software and AnswerBook Packages...) |
(Installing Server) |
Installing Packages on a Server for... (Application Packaging Developer's Guide) Creating an Install Server (SPARC Installing Solaris Software) |
Delet* |
Delete All Silence (Solaris Advanced User's Guide) Deleting a Line (Solaris Advanced User's Guide) Deletion of the New Selection (OLIT Reference Manual) |
If you are unable to find an error message documented, please report it to us by sending e-mail to msgdoc@Eng.Sun.COM (this address is an autoresponder alias, not an actual person).
