The AnswerBook navigator window comes up, but the document viewer window does not. This message appears on the console, and the message "Could not start new viewer" appears in the navigator window. This situation indicates that you have an unknown client or a problem with the network naming service.
Run the ypmatch(1) or nismatch(1) command o determine if the client hostname is in the hosts map. If it isn't, add it to to NIS hosts map on the NIS master server. Then make sure the /etc/hosts file on the client contains an IP address and entry for that hostname followed by loghost (reboot if you changed the /etc/hosts file). Check that the ypmatch(1) or nismatch(1) client hosts command returns the same IP host address as in the /etc/hosts file. Finally, quit all existing AnswerBooks and restart.
For more information on the NIS hosts map, see the section on the default search criteria in the NIS+ and FNS Administration Guide. If you are using the AnswerBook, "NIS hosts map" is a good search string.
