Action
First, make sure that the server is up and running. Second, make sure that the server is in the /etc/hosts file of the client system by typing: ping server name. Third, check the license daemon on teh server to see if it is running. Fourth, make sure that there is an elementary license file on the client:
cd /etc/opt/licenses
more sunpro.loc
Fifth, in the
sunpro.loc directory are there only text license files such as
sunpro.lic,1? Sixth, on the client check:
% cd /etc
% more nsswitch.conf | grep hosts
hosts: nis [NOTFOUND=return] files
This says that it will use the nis server to look up the IP address. If it is set first for
nis and the
/etc/hosts file has the server listed by name, change the line to
Then see if it can find it. If not, try truss and snoop to see what is going on.
