This message can appear while a system is booting, indicating that the init(1M) program is missing or corrupted. Note that /etc/init is a symbolic link to /sbin/init.
Boot the miniroot so you can replace init(1M). Halt the machine by typing Stop-A or by pressing the reset button. Reboot single-user from CD-ROM, the net, or diskette. For example, type boot cdrom -s at the ok prompt to boot from CD-ROM. After the system comes up and gives you a # prompt, mount the device corresponding to the original / partition somewhere, with a command similar to the mount(1M) command below. Then copy the init(1M) program from the miniroot to the original / partition, and reboot the system.
# mount /dev/dsk/c0t3d0s0 /mnt # cp /sbin/init /mnt/sbin/init # reboot  |
The error number is 2 if /sbin/init is missing, or 8 if /sbin/init has an incorrect executable format. This is usually followed by a "panic: icode" message. The system tries to reboot itself, but goes into a loop, because rebooting is impossible without init(1M).
For more information on booting the system, see the section on halting and booting the system in the System Administration Guide, Volume I.
