This occurs either when the destination host is down or when problems in the network cause lost transmission.
First check the operation of the host system, for example by using ping(1M) and ftp(1), then repair or reboot as necessary. If that doesn't solve the problem, check the network cabling and connections.
No connection was established in a specified time. A connect or send request failed because the destination host did not properly respond after a reasonable interval. (The timeout period is dependent on the communication protocol.)
The symbolic name for this error is ETIMEDOUT, errno=145.
