After a power cycle, the machine comes up with error messages saying: corrupt label - label checksum failed or corrupt label - wrong magic number . format(1M) showed:
0 unassigned wm 0 0 (0/0/0) 0 1 unassigned wm 0 0 (0/0/0) 0 2 backup wm 0 - 5460 4.2G (5460/0/0) 4154160 3 unassigned wm 0 0 (0/0/0) 0 4 unassigned wm 0 0 (0/0/0) 0 5 unassigned wm 0 0 (0/0/0) 0 6 unassigned wm 0 - 2730 2.1G (0/0/0) 0 7 unassigned wm 2730-5460 2.1G (0/0/0) 0 |
The disk label (VTOC) is kept on the block 0 of cylinder 0. The label will eventually get overwritten by database programs using raw partitions if the raw partition begins at cylinder 0. (Unix filesystems avoid this area of the partition.)
The workaround is to go into format and get the backup label using the backup command. Relabel the disk using this backup label. You should then be able to access the disk.
Backup the data on this disk.
Go back to the disk and relabel it, starting the raw partition at cylinder 1 (This looses one cylinder, but prevents corrupting the VTOC).
Label again.
Restore the data from your backup.
