This is a kind of bad trap that usually causes a system panic. When this message appears after a bad trap message, a system text or data access fault probably occurred.¤ In the absence of a bad trap message, this message might indicate a user text or data access fault. Data loss is possible if the problem occurs other than at boot time.
Make sure the machine can reboot, then check the log file /var/adm/messages for hints about what went wrong.
¤ See the message "BAD TRAP" for more information.
