setuid and setgid shell scripts refuse to run - they simply return an error message similar to /dev/fd/3: /dev/fd/3: cannot open. (The number following /dev/fd/ is not necessarily 3.) The first line of the script properly starts a shell, and the filesystem containing the script is not mounted with the nosuid option.
Running truss on the shell script reveals that a call to open(2) is failing with error number 6 (ENXIO):
open("/dev/fd/3", O_RDONLY) Err#6 ENXIO
Setuid and setgid shell scripts use the file descriptors in /dev/fd. The contents of /dev/fd are a File Descriptor Filesystem (fdfs) on Solaris 2 and have no connection with floppy disks!
Ensure that the fdfs is mounted as /dev/fd. The following line should appear in /etc/vfstab exactly like this (with NO initial comment symbol):
fd - /dev/fd fd - no - |
It may be possible to remount /dev/fd without rebooting by running the following as root:
# mount fd /dev/fd |
Some administrators, unaware of what /dev/fd is for, comment out the entry in /etc/vfstab that mounts the fdfs (File Descriptor filesystem). This may go unnoticed until an attempt is made to run a setuid or setgid shell script.
