The workaround is to remove the PPP 3.0.1 packages and replace them with the PPP packages off of the Solaris 2.6 release CD-ROM. For example:
# pkgrm SUNWlicsw SUNWlit SUNWpppk SUNWpppm SUNWpppr SUNWppps SUNWpppu
: {package remove info}
# cd /cdrom/cdrom0/s0/Solaris_2.6/Product
# pkgadd -d . SUNWapppr SUNWapppu SUNWpppk
: {package add info}
NOTE: If the Solstice PPP 3.0.1 package is configured and currently in use on the system, the user should save any of the previously entered PPP configuration info so that it may be restored after the OS services have been installed. (pkgrm(1M)the 3 ppp packages installed from the 2.6 release CD, and pkgadd(1M) all of the ppp packages from the Intranet Extension cdrom again, then redo config.). If the Solstice PPP 3.0.1 package was not used on the system, there is no reason to reinstall it. Use /usr/bin/pkginfo to check the installed packages.
This is documented in Chapter 9 of the Solaris Server Intranet Extension Installation and Release Notes Solaris 2.6 manual.
