Make sure that the software matches the architecture and system you're using. The file(1) command can help you determine the target architecture. If you're using SunOS 4.1 software on a Solaris 2 system, make sure that the Binary Compatibility Package is installed. You can check for it using this command:
$ pkginfo | grep SUNWbcp |
